Took the car out just now, and noticed the rev counter and clock had both stopped working.
Too late to investigate now, but is there a particular reason why they both should stop together? A fuse or wire responsible for both.
Every other gauge works fine.
Rev counter and clock stopped working
Standard reply to this question: Replace fuse 21, then sort your radio wiring out, or fix the glovebox light if it's an early car.
polsta
brian. how do you fix the glove box light ? he mentioned earlier it needs doing, its got the 2 wires there but no bulb
could this have any bearing on my problems with the speedo if you say thats linked ?
The lack of bulb could well be your problem (but only on '88 cars or earlier) as the spring in the base of the bulb holder tends to push the contacts inside the holder together and shorts them out.
Later cars run the glovebox light from fuse 4, and it's still important that a bulb is fitted to prevent thi fuse blowing.
