stereo / speaker loom tech 1 sport
polsta
Post Tue Jul 12, 2011 5:47 pm
To keep this seperate thread as not to get confused...
car a 1987 325i tech 1 sport
Had a new thatcham cat 1 alarm system installed today, glove box and trim out etc, asked him about the stereo and to have a look at the wiring... the wires for the stereo are a bit ropey, not major bad, but there doesnt seem to be any proper stereo loom or any front speakers
what he told me to find out, was should there be a proper look bit for the stereo ? and is it on a plug, maybe to the elft of the glove box he said there might be a loom that plugs in and has the speaker/streo wires or something ?
if that is the case, then its missing , and ..can i use the same loom bit from the is breaker ?? (a 1990 318is)
appriciate any help
Post Tue Jul 12, 2011 9:31 pm
Any form of radio/ICE on an E30 was an optional extra, so there was no factory fitted loom, apart from the tweeter wires to the front doors.
The speaker looms are usually tightly twisted pairs, but I've seen parallel twin used as well, and they're not always routed in the same place, depending on how closely the fitting dealer was following the official instructions. I've found rear speaker wires going back either sill, and also under the centre consoles and then under the carpet on top of the transmission tunnel. No reason why you can't use the iS bits.
