I'm hoping to re-assemble my complete rear beam over the next few days, have a few questions
The trailing arm bushes have one one end a sort of collar on them, am I right in thinking these are fitted so they are on the outside of the arm? What to use as lube, a dab of grease or wd40?
I had a look the other day and couldn't figure out what way the brake lines are routed on the trailing arms. If anyone has any pics or know of any good pics I can look at for when I do mine?
Anything, even obvious stuff, I should know about when putting the rear beam back together? Can the trailing arm bushes be torqued up on the ground or does it have to be done on the car?
What way do people usually set the camber/toe tabs to start of with, something thats close to optimum before getting the tracking done properly.
Trailing arm bushes, camber tabs and brake line question
Jozi
clarko74
Yes, the collar bit of the bush goes on the outside. Don't use anything oil or grease based as it'll stay in there and the bush will rotate on it, which it's not supposed to do. BMW have a special lube that sets but a bit of washing up liquid does that same thing.
The brake line goes along the inside bottom of the trailing arm, around the back, then up and around the front in between the trailing arm and disc backing plate:
There are various ways to put the rear beam back in depending on the jacks/ramps available and if you're doing it on your own or not. I did it on my own and with just my cheapo halfords jack and a big pile of 2x4 bits of timber. I attached the trailing arms to the beam jacked one side up then propped it up with timber then did the other side, then alternated until the beam was in position and I could get the bolts through and done up.
You shouldn't really tighten the trailing arm bolts up until the trailing arms are in the position they will be in when the car is standing on it's wheels, as if they are tightened in the wrong position the bushes will be stressed all the time. This is difficult to do unless you have some sort of 4 post lift or similar and made more difficult if you also have the toe/camber to set too. I measured the relationship of the trailing arm to the car body/rear beam before I took it apart then set the trailing arms to this level (with the beam off the car) with the toe/camber bolts as close as possible to the centre (as they would be with a standard ream beam), I then did it all up and put it back on the car as above. You should then get the wheel alignment checked properly though. The method above is probably not how to do it by the book but it worked for me.
HTH
HTH
clarko74
Jozi
Thats Clarko thats perfect. Never thought of soapy water, will give it a go tomorrow at some stage and get rebuilding the rear beam a little
Should be ok fitting the beam it self, car is on a spit, just need to turn it vertically
I may have to losen/re-tighten the trailing arm bolts after letting the car on it's wheels and get a better idea of where their resting position is.
