I have been told there is some oil combo I can use to get rid of the awful drone and chatter caused by solid clutch and lightened flywheel.
Im using an e36 M3 5 speed box.
Anyone have a solution for me?
Gearbox chatter due to lightweight flywheel
turk
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
penton08
A sprung clutch will go a small way in helping, but I'm sure it never really goes away. Thicker oil might help the rattle but it will not help cold gear shifts, The 3.0l box uses ATF anyway so im not sure where that leaves you, maybe ask Dave m3 he is a lightweight flywheel veteran.
leeparkes
Let us know how you get on, i too have the annoying layshaft rattle with a solid flywheel.
I use Redline MTF, stopped the rattle in my 6 speed, and it was much better value than the BMW "lifetime oil" @ £135 per gallon
Mikey_Boy
Honestly I don't think there is a great deal to be done here to improve the situation. The flywheel and clutch assembly are weighted usually to give good idle quality and, yes, you guessed it, minimise layshaft chatter at idle. Lightening the flywheel and stiffening the clutch will only make the situation worse. If you can put up with really crappy cold shifts, thickening the viscosity on the gearbox oil will help, ATF constrained or not.
The other way of improving the problem (if you are able) is to raise the idle speed by increments of 50rpm until the chattering disappears - 100rpm or so makes a big difference!
Mike
Mike
leeparkes
I tried this by triggering the aircon 'on' signal to the ECU.Mikey_Boy wrote:The other way of improving the problem (if you are able) is to raise the idle speed by increments of 50rpm until the chattering disappears - 100rpm or so makes a big difference!
Mike
It quietened it down a bit but not enough. Im going to try the MTF next.
BTW Lee, my box wasnt rattling because it was worn, only 2000 miles on it
leeparkes
Mines got about 130k on it and only rattles when hot, in traffic its annoying not to mention embarrassing with folk walking past and drivers next to me giving that wtf look.
Feel like wrapping the coont in sound deadening
ultralinear
I too have this problem with my lightened flywheel.
I have developed 'constant depressed clutch at traffic lights' syndrome. Also known as 'unusually large left calf' syndrome.
I might try the idle speed trick. Thanks.
suchy
- True Zone Relic
Oh mine has this too on my M20- rattly in neutral on idle without clutch depressed? I do indeed have a lightened flywheel/heavy clutch combo. It's been on there for years so I'm used to it, but I've always thought one day it would need sorting!!
I'm not a fan of sitting on the clutch at lights/junctions etc. so it gets put into neutral, but as I mentioned, I've run this combo for so long I'm used to it!!
Is the M20 box different or is mine still shagged as this is only relevant to the later boxes?
m8782538
I have that on my current daily driver but its not an E30, mine is a worn Clutch release bearing, rattles like crazy unless the clutch is depressed, even when in gear moving, luckily the rev's drown out the rattle then. lol.
