rear disc conversion,different regulater valve?
dodgydoughnut
Post Sun Jul 10, 2011 10:15 pm
swapped over rear end complete to a rear disc setup,works well but locks rear wheel to easy,looked on realoem and seems there are two types of restrictor valves on rear brake lines,one for drums and one for discs,i take it these need changing aswell then.?anyone done this,or not normally a problem
clarko74
Post Mon Jul 11, 2011 9:15 am
I think you are right, when I was talking to Ant before I did my rear disc conversation he gave me a valve from an all disc car and said that I should fit it. I'm yet to fit it so don't know how hard but can't imagine it is too tricky.
I did my rear disc conversation a couple of months ago and haven't had any problems with locking rear wheels with the old valve.
clarko74
randomspeedfreak
Post Mon Jul 11, 2011 10:44 am
you boys recon the conversion is worth doing?
Green
Post Mon Jul 11, 2011 1:05 pm
randomspeedfreak wrote:you boys recon the conversion is worth doing?
Definitely worth it.. gives you an excuse to sort the rear bushes out as well :D
clarko74
Post Mon Jul 11, 2011 8:39 pm
And much more importantly they look much better through your wheels than a rusty drum does!
clarko74
dodgydoughnut
Post Mon Jul 11, 2011 9:17 pm
run on 888 toyo normally,but setting up new engine,fitted some shit 195 60 14,was wet and under slightly heavy braking was locking rear,explains why i was doing set of rear pads per trackday
