Hi,
Can someone please tell me where the two wires under the glovebox from my newly fitted cruise control unit go..
Mainly the white one i feel goes to the big white box, can only go there i think..
The blue on goes to the brake light swtiched?
this is how ive wired it and it dont seem to work...
thanks for your help in advance.
joe
ALPINA>>>>cruise control wiring help
The power feed and the brake switch connection are both to the two pin socket in the top RH corner of the accessories socket.
Wires should be purple/? and green/red. Don't know of any blue and the white is clutch control in the actuator.
jotz
hi
The white one has been bridged, guess thats for manual cars
But i have a blue/brown single wire which not sure what this is for..
could it be this wire is for a later car??
gonna test it now will get back.
thanks
thanks
jotz
ok
will do
hopefully get some more advise at the pod..
thanks again guys
will do
thanks again guys
jotz
so the white plug that has been bridged,, buy BMW it seems,, i dont need to connect as my car is auto..?
is this correct?
is this correct?
The clutch pedal switch on manual cars is connected in series with the green/red wire that connects to the brake light switch wire at the accessories socket.
Road speed wire from the instrument cluster should be blue/yellow. Blue/brown is 'cruise enable', connects to the starter inhibit relay on auto cars, but isn't used on manual cars.
jotz
Ah ha.... ok now it makes bit more sense..
will try this tommorow.
fingers crossed!!
thanks
fingers crossed!!
thanks
jotz
ok
so today i sussed out the connection for the starter inhibitor relay, which i did.
also check all this QUOTE:
Disconnect the cruise ECU and the actuator. Use a meter to check that there is a low resistance (not zero) between the green/red wire (9) of the ECU plug and earth.
Switch the meter to volts, and check that this wire goes to 12 volts + when you press the brake pedal with the ignition on.
Connect a 12 volt 5W or 10W bulb between the purple/white (1) of the ECU plug and brown (23) and check that it lights with the ignition on.
But alas.....shes still not doing as shes told!!!
Is it that i gotta buy bit of 3x2 and wedge it to the accelerator pedal??
Anymore ideas chaps?
