Passenger mirror clicking?
blingsta
Boost Junkie
Post Sat Jul 09, 2011 8:32 am
Was working but has since started to make a clicking noise and no movement? Drivers works fine..
Could it be the loom?
Post Sat Jul 09, 2011 9:53 am
A single click when you push or release the switch, or continuous clicks when you try to move it?
blingsta
Boost Junkie
Post Sat Jul 09, 2011 10:04 am
Single click when I press Brian, sounds like a short ?
Post Sat Jul 09, 2011 10:08 am
Does it make the click when you go up/down or side to side or both?
blingsta
Boost Junkie
Post Sat Jul 09, 2011 10:13 am
Both.. The mirror doesn't move at all, just 1 click any time I try a direction
Post Sat Jul 09, 2011 10:25 am
A click from both mirrors when you move either mirror up/down is normal, but you don't normally hear it because of the noise from the motor. Your problem doesn't sound like this though.
First check is to remove the mirror glass, then the four screws that hold the motor assembly in place, and use a bulb to check that there is 12 volts between the black and brown wires at the motor, with the ignition on.
While you have the assembly apart, check the the clip that holds the plastic rack in contact with the drive motor pinion is intact.
blingsta
Boost Junkie
Post Sat Jul 09, 2011 10:35 am
Ok Brian, as soon as I get time, I'll check and report back my findings .. Thanks
blingsta
Boost Junkie
Post Sat Jul 09, 2011 10:47 am
Brian, can I eliminate it by swoping mirrors around? Just plug the drivers into passenger side and see if it moves?
Post Sat Jul 09, 2011 12:55 pm
Swapping mirrors won't prove anything. Test as above.
BEERBOY123
Post Sat Jul 09, 2011 2:30 pm
Sorry to butt in, how do you remove the mirror glass?
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
Post Sat Jul 09, 2011 6:25 pm
BEERBOY123 wrote:Sorry to butt in, how do you remove the mirror glass?
White plastic retaining ring, fixed to the back of the glass.
There's a small hole underneath the mirror housing where you insert a small screwdriver and engage with some teeth on the outer edge of the ring, then lever the ring around a few degrees.
I find it easier to tilt the glass fully upwards and then push a very small screwdriver in under the glass, where you can just see the teeth on the ring.
blingsta
Boost Junkie
Post Mon Jul 11, 2011 9:50 am
Update Brian..
Only clicks when I try up and down.. I've taken glass off and the only live I'm getting is on the black wire !
Everything else is as it is
blingsta
Boost Junkie
Post Mon Jul 11, 2011 10:07 am
Another update !!!
I pulled the rubber sleeve off from inbetween the door and body just to check for obvious signs of corrosion... No signs.. So I put the sleeve back on and guess what ????
The mirror now dances to my command !!!!!!
Woohoo
Post Mon Jul 11, 2011 10:32 am
You've eliminated the fault without knowing what it was and fixing it properly, so the chances are that one day it will return. This is why I advocate disturbing nothing until you have pinpointed the fault!
The motor assembly appears to have two motors in it, but only one is a motor - the other one is a clutch actuator, which is what you heard clicking. As I've already said above, this is normal, but you don't normally hear it because of the motor noise.
After the two red/black wires in the driver's door plug, the blue/white wire which feeds the black wire on the passenger mirror (and passes through BOTH door plugs) is by far and away the most likely pin to suffer corrosion. This is because the corrosion is an electro-chemical reaction, and occurs on pins that are live. Red/black is first because it's live all the time, and blue/white is second because it's live all the time the ignition is on. All the other pins are either not live, or only live for short periods, and if they corrode, it has spread from the pins above.
The rubber cover on the door plug cannot be replaced properly with the plug in place. The plug needs to be disconnected, the cover fitted, and then the plug reinserted.
blingsta
Boost Junkie
Post Mon Jul 11, 2011 10:38 am
I will do that now Brian.. As you said, as I haven't pin pointed the problem, I'm sure it will as you said come back to haunt me, what is the next procedure please? Clean all contacts/pins in door connection?
Post Mon Jul 11, 2011 10:43 am
If it's only the passenger plug you've disturbed, then it's likely that this is where the problem is, rather than the driver's door, so unplug it and do a clean up, as you say.
blingsta
Boost Junkie
Post Mon Jul 11, 2011 10:45 am
Thanks Brian
