325i 1987 manual - Starting Problem - HELP!!!!
mikeyeats
Post Fri Jul 08, 2011 9:23 pm
I need some help. My beloved 1987 325i has been left standing for about three months. It always starts first time every time and the last time i drove it was fine. Now it won't start.
It seems to have no fuel, and no spark, but will turn over well, the coil has power.
Things i have tried:
1. Have hot wired the fuel pump (it gives good pressure). it also works if i hot wire the relay.
2. Have measured the Crank sensor (960 ohms - as should be)
3. Have measured the coil, seems ok
4. Have checked Fuse 11, fine
5. Have tested the two relays under the little hood (near strut)
6. Changed the ECU (073 type) (New one could be faulty - but unlikely)
7. Taken spark plug out but no spark when touched on earth
8. Checked inline 50amp fuse from battery - Ok
9. Checked two relays behind the glove box (orange), they click on the battery.
10. Have read around 1 million other people with same problems on various forums, they rarely post the fix though.
Any help or advice would be greatly appriciated, its driving me crazy!!
fowler
Boost Junkie
Post Sat Jul 09, 2011 6:40 am
+1 on what he said
EX A-Tech Workshop bitch !!!
gone but not forgotten
mikeyeats
Post Sat Jul 09, 2011 12:22 pm
Thanks for your advice. i have checked the relay there is 12v at pin 30, and when i bridge it i can hear fuel flowing, i think the relay is ok.
I also get 946ohms at the 2x ECU plugs as you also suggested, so they are ok too.
I think this means its either both ECUs are faulty (does anyone have another 073 one?), or the flywheel pin has come off.
If its the flywheel, will i need a new one? Is it a good time to go 1.3 and is it right that i should do the clutch at the same time?
any further advice appreciated thanks
Post Sat Jul 09, 2011 1:50 pm
If you change to M1.3 you won't need to do anything to the flywheel, or remove the gearbox to get at it. The sensors on the flywheel, or the pin to trigger them, isn't used with 1.3.
mikeyeats
Post Thu Jul 21, 2011 8:46 pm
Am still having no luck with my car, just wondered if anyone knows what else i could try before i go mad! Have had a garage have a look, with no luck.They think it is the ECU. Does anybody has an ECU with an 073 ending? All info very much appreciated.
A guy i met at the Bimmerflex meeting, told me that it could be a connection behind the instrument cluster and i should remove it and try to start the car, has anyone had this before?
Post Thu Jul 21, 2011 9:50 pm
This is a very, very, simple engine!
Assuming there hasn't been a catastrophic mechanical failure, there should be compression, so all it needs to run is sparks at the correct time, and fuel injected into it. The timing of the fuel isn't particularly important, as long as it's in reasonably the correct quantity.
If you don't have sparks, then the only candidates are the coil, distributor, HT leads, ECU, the supplies to the ECU and the crank sensors. If you don't have fuel pump activity either when cranking, start reading that list at ECU.
ECU failure is possible, but rare.
Start testing by connecting an AC voltmeter to the crank sensors and see if they produce anything detectable when cranking. I've no idea what sort of output to expect, but I'd expect to see something if the crank sensors are working and the pin is in place.
chopper
Post Fri Jul 22, 2011 8:57 am
Hi, I have the same problem with mine, it cranks over really fast, ive checked the timing which is all good, it seems like there is no compression, someone told me I can I check is by removing the spark plug and then start it, and you should hear air from where the pistons move?
mikeyeats
Post Wed Aug 03, 2011 10:33 pm
Fixed, Fixed, Fixed! Thanks to everyone helped me with advice and parts, my car is now fixed, had a very quick drive back from Reading, where i took the car to get fixed by Munich Motors. The guy is highly recommended!
The problem with the car was an earth fault and power did not get to the ECU from the relay (I think thats what he said).
Thanks again everyone. You all know your stuff, very impressed.
clarko74
Post Thu Aug 04, 2011 12:50 pm
Glad you got it Sorted Mike (and that it wasn't the ecu you got from me!).
clarko74
