Rear arch replacement
Razza
Sun Jul 03, 2011 9:04 pm
Motor is rusting bad at the rear arches. I was considering trying to get a rear arch replacement kit for each side but then stumbled upon this on ebay:
http://www.ebay.co.uk/itm/BMW-E30-N-S-R ... 500wt_1156
From a bodyshop perspective would simply painting and switching each panel work out cheaper than cutting out the existing rusty arch and welding in a replacement then painting?
If so does anyone know how much the rear panels retail at and were to get them, BMW part number is 41.35.1.961.529
mattycoops43
Sun Jul 03, 2011 11:14 pm
Far more work to change the whole thing. It's not a bolt on, so is cut and welded like a repair patch, except there's a hell of a lot more to cut and weld!
1990 325i se "weinrot"-How did they know?
Razza
Mon Jul 04, 2011 9:03 pm
That will explain why I couldn't find it on the OEM site :?
Arch replacement kit it is
Topblag
Mon Jul 04, 2011 9:09 pm
Hadrians panels are the ones which have been used on 2 of my E30s.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
**BANNED**
Mon Jul 04, 2011 11:55 pm
Do make sure you are supplied with matching arch repair panels.... winkeye
Youth is wasted on the young.
Tue Jul 05, 2011 12:17 am
daimlerman wrote:Do make sure you are supplied with matching arch repair panels.... winkeye
Ask Stevie :mad: for advise
Jozi
Tue Jul 05, 2011 11:25 am
Have a good poke around the inner arch as well as it to could be rotting away.
