Hi
Does anyone have any ideas where i should start looking for holes? The wet patch was right under the clutch pedal.
Andy
Heavy rain last night = wet drivers footwell this morning
chippenham_touring
doug325i
Firstly check all the gutters to make sure water is not overflowing. Could be running down the inside of the engine bay. somewhere. Happens at this time of year with leave falling off trees etc... Also check your mirrors are pushed in fully.
Doug
Doug
Check the "elephant trunk" drain for heater air intake (grills below windscreen) isn't blocked.
It's on the bulkhead between the battery tray and the rear exhaust side of the engine.
chippenham_touring
Thanks Brian, it seems to have sorted it.
Andy
Andy
dsio
Could you describe this thing further at all?Brianmoooore wrote:Check the "elephant trunk" drain for heater air intake (grills below windscreen) isn't blocked.
Dont spose there is an image anywhere of this drain.
dsio
Damnit. Mine was clogged with mud and little sticks. Took it off and cleaned it, dont spose theres a trick to getting the bastard back on?
Had my floor filling up with water for 6 months now, and 2 massive holes in the floor. Cant believe nobody said this before!
