I've decided to remove the rear axle but the handbrake cable will not budge.
Can I just remove this from the back of the handbrake from inside the car and pull it through or will it have to be removed from the brake end?
Rear Axle and handbrake cable
tom325sport
asmith88
if your removing the whole back axle then i would imagine you would need to remove it from the handbrake end, and pull it out the tube
1990 brilliant red 318 is
Bristol_Jer
If you can remove the cable outer from the tube in the transmission tunnel then you can pull the cables back through after undoing them on the handbrake lever. I did this on mine, it was easier to remove the cables from the brake end with the beam off the car I found
tom325sport
Ok thanks. Will try this tomorrow.
Do you mean the tube that goes from the brakes up to the petrol tank?
- **BANNED**
Handbrake cable is held by a cunning roll pin device within the brake hub,the un-wary loose these to the darkest corner of the garage,and the little buggers are swines to find....
pulling the cable out of the tubes is fine,after they have been released from inside the car,of course,snag here is that the furrule on the outer rusts solid to the end of the tube,so whichever way you tackle this,there will be blood,sweat and tears,and perhaps your next door niegbours kids will be learning some new words...
Enjoy!
Enjoy!
Youth is wasted on the young.
tom325sport
Yep they have already learn't a few this morning!
Can I just take a hack saw to the tube that is between the brake and fuel tank rather
Than pulling it through? I've removed the clip that hold the rear brake shoes together, But it still won't budge!!
Little swine!!!
Little swine!!!
clarko74
You can take a hacksaw to the outer cable, this is the easiest way to get the beam off and out of the way. You then still have the outer cable to get out though.
Lots of wd40 left to soak for a while between the cable end ferrule and tube that it fits into then get mole grips on it to twist them out. Don't be too viscious with the mole grips though as it is possible to rip the metal tubes out of the chassis.
clarko74
tom325sport
What a joy that was!!! Cut the hand brake cables and pulled through. That was easy. Realeased the
2 22mm bolts and plates, hit the studs up into the car as well as the diff bolt and all other wires etc to remove the rear axle. Would it move? Would it hell!!
Any ideas?? The axle bushes won't move!
rob0r
Put the 22mm nut back on the axle pin (without the plates) and hit the nut with a hammer until the pin releases upwards into the car. The pin is splined and is designed to be removed, this is how I remove all BMW axle bushes, it makes it very easy.
tom325sport
Thanks for the reply. I've released the pin upward in the car but still no movement.
Any other options?
Any other options?
Steel bar up the hole vacated by the splined bolts and wriggle the alloy tube until it lets go, hopefully without breaking off near the top.
tom325sport
OK great. I will get something in there then!
Thanks!!!
Thanks!!!
KimH
If the Subframe mounting bushes disintegrate, as mine had - leaving the inner alloy tube attached to the chassis - simply put the steel bolt up from underneath approx 2-3 inches and tap the bolt head gently, side to side, back to front, in a variety of horizontal directions. Mine came off in seconds.
The tube itself sits some 1cm into a shallow hole in the chassis, so lever it firmly but gently and it should come out - in one piece if you're lucky.
I imagine the job is a tad more difficult of the bush is still whole and restrained by the subframe - in this case, and unless you need to reuse it, I'd cut/hacksaw/burn the rubber out to lower the subframe first.
