320i CO
koos
Post Tue Oct 18, 2005 7:04 pm
Hellooooooo chaps.
Put a 2nd hand afm on the beemer and wanna check the CO's with the machine at work(not sure why we have one). Does anyone know what the CO should be and how to check it eg: engine temp etc. Oh yeah its a 320iSE 91 model.
MiTcH
Andy_magic
Post Tue Oct 18, 2005 9:20 pm
The CO should be 1-1.5% people reckon they drive best set at 1.5%
The engine should be up to operating temperature before checking.
If you need to make adjustments, do the adjustment and then run the motor at about 2500rpm for 20-30 seconds and let the engine idle again, then re check the reading.
HTH
