Whining Wheel bearing
330-singh
Post Mon Oct 17, 2005 9:56 pm
Bit of advice please....
I have a slight whine coming from the front drivers side wheel bearing. Is there a write up on how to change this anywhere? or can someone tell me how easy (or not!) it is to do....any specialist tools required.
Thanks in advance 8O
By the way its a 1991 316i
M5pilot
Post Mon Oct 17, 2005 10:07 pm
32mm socket required. very strong breaker bar with a massive extension and lots of strength. Other than that its one of the easiest jobs to do.
330-singh
Post Mon Oct 17, 2005 10:10 pm
ok that sounds do-able.....just incase does anyone know of a reputable garage in either the Slough area or Watford area?
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Oct 17, 2005 11:03 pm
pretty easy mate. it's worth a mention that the abs and non-abs bearings are interchangeable. Pretty easy job. along lines of.
off with wheel,
off with caliper
off with brake disk (5mm allen head bolt)
off with heat shied thingy
pop of centre dustcap on
push out little bits of bent metal (what are they called?)
blast it with the breaker bar
hub nut off,
bearing off
pack in extra grease and do reverse operation.
that's ottomh but it was quite easy. not sure how important it is to get the exact torque setting on the hub nut but I did have a torque wrench so I dunno...
I reckon that's about it. I'm sure if I've missed anything important somebody will put us straight :)
ianeire
Post Mon Oct 17, 2005 11:06 pm
Did one on a saxo at the weekend, bit of a balls to get out but got there eventually. Eventually had to use a press to press the old bearing out and pop the new one in
1990 Brilliantred 325i Sport
www.e30owners.com Irish e30
Post Mon Oct 17, 2005 11:34 pm
i just took the dust cap off, put the wheel back on, lowered the car again.
And well undoing the 36mm nut is a piece of p!ss as all the weight of the engine helps, but u might still struggle as your 1.6 weighs nothing!
Doing it this way....... 20mins a side easy when u know how!
HTH
330-singh
Post Tue Oct 18, 2005 10:15 am
Thanks all.
I will give it a shot sometime this week....can't imagine it being too difficult from the descriptions above! :P
330-singh
Post Tue Oct 18, 2005 10:53 am
Just to clarify, is it a 36mm or a 32mm socket I need? I think the largest I have is 32mm.
kam-325i
Post Tue Oct 18, 2005 11:52 am
The torque setting is 190Nm, i remmeber this as its the highest setting my torque wrench goes up to.....
