320I DIFF RATIO
E30SPORTMAD
Thu Jun 02, 2011 1:30 am
can anyone tell me what the ratio is for "87 320i standard open diff? thanks
torquey
Thu Jun 02, 2011 7:50 am
3.64 upto 9th/1987 after 9th/1987, 4.10
clarko74
Thu Jun 02, 2011 8:54 am
torquey wrote:3.64 upto 9th/1987 after 9th/1987, 4.10
Not quite.
320i 9/85 to 9/87 came with either 3.64 or 3.91. My late 86 320i had a 3.91.
http://www.e30zone.net/e30zonewiki/inde ... ferentials
clarko74
E30SPORTMAD
Thu Jun 02, 2011 11:34 pm
Thanks guys i must find out the exact month and year of the car so it mite make it easyier to work out the ratio, dont want to strip the mans diff down and then say its not what i want if i can help it,
Jim320i
E30 Zone News / COTM Team
Thu Jun 02, 2011 11:36 pm
Mines a 87 320i, with a 3.64 diff... Found out the other day so looking to upgrade it to a bigger one like the 4.10 or larger
E30SPORTMAD
Fri Jun 03, 2011 12:47 am
Jim320i wrote:Mines a 87 320i, with a 3.64 diff... Found out the other day so looking to upgrade it to a bigger one like the 4.10 or larger
is it small case or medium case housing?
**BANNED**
Fri Jun 03, 2011 1:54 am
Jim's is a small case diff mounted behind an autobox,what Jim wants to do(I think)is make his car a bit faster at the traffic light GP,so he's looking for a small case 4:1 or possibly a 4:27.
Youth is wasted on the young.
Jim320i
Fri Jun 03, 2011 8:57 am
:) Thanks Malc. :D
Small like Malc said pal. But its on an auto, also like Malc said. :D
clarko74
Fri Jun 03, 2011 11:04 am
Mine was manual and small case.
clarko74
**BANNED**
Fri Jun 03, 2011 12:35 pm
clarko74 wrote:Mine was manual and small case.
Now if you were to want a slightly taller 3.64,and Jim would settle for a slightly shorter 3.91,all you have to settle is the difference between Leicester and Kent.... :D
320Touring
Fri Jun 03, 2011 12:37 pm
Jim320i wrote::) Thanks Malc. :D
I think m40 tourings (auto) had something like a 4.45 :D
clarko74
Fri Jun 03, 2011 1:00 pm
Note that I said 'was' in my post. I changed it to a 3.64 medium case lsd when I put my 2.5 lump in.
took the 3.91 down the tip in the end, couldn't give it away, tried selling on here, then on ebay (some fella bought it for £5, paid and then never collected it as he wanted a medium case one), then tried to give it away without any takers.
clarko74
damageandyy
Mon Jun 06, 2011 12:48 pm
whats it like with a 3.64 compared to a 3.91, my 3.91 has just blown up so need a new one was thinking of swapped ratios.
**BANNED**
Mon Jun 06, 2011 12:59 pm
damageandyy wrote:whats it like with a 3.64 compared to a 3.91, my 3.91 has just blown up so need a new one was thinking of swapped ratios.
Which engine do you have?
Chome bumper E30 up to the introduction of the 325i all had small case diffs,325i brought the medium case diff into E30 use.
Small case diffs have 6 bolts holding the rear cover,medium case diffs have 8 bolts here.Medium case diffs are bigger,hold more oil and have bigger bits inside to make them stronger....
3.64 ratio;
73mph at 3000rpm
4.1 ratio
65mph at 3000rpm
(fiqures for manual 'boxes only)
Never tried a 3.91,but it will fall between the above quotes.
