the brakes on my 325 seem really crap. it has new discs allround (off when i bought it) and am guessing new pads.
they work fine i suppose for normal driving but i intend on doing a trackday and dont think they will last 2 minutes.
they just dont seem very sharp if you know what i mean.
am after a cheap upgrade.
dont want mega brakes just a bit sharper
brake upgrade
WMS kit is the best option but that is circa £600 for the kit, you can run that on 15" BBS also.
A good "cheap" upgrade is basically fit a clio servo and have the calipers and pistons overhauled. Run quality pads (like Yellow stuff/Red stuff) and decent vented discs. A change of brake fluid and a set of braided lines would probably do you the world of good but if you work out how much that will cost you should just talk to keri and get some WMS ones, if your doing a trackday it pays for itself.
- Brianmoooore
Standard brakes are good enough for the odd track day if they're working as they should.
No mods required; just get what you have working as it was when it left the factory.
Clio servo isn't an upgrade - it's just a way of fitting a servo of any kind, when the space for the standard one is partly occupied by the inlet manifold of a M50 or M52 engine.
No servo 'improves' the brakes on any car; it just makes it easier to work them.
- Brianmoooore
Also check that the calliper sliders are in good order and greased, and that the pull rod across the car behind the heater is adjusted correctly.
- Brianmoooore
It's adjusted correctly when the brake pedal is just short of its upper stop.
