E30 Cabby Windows rattle when up
Bela
Mon May 23, 2011 5:31 pm
Hi Guys,
when driving around in theres quite a bit of rattling when going over pot holes etc whilst the windows are wound up but no noise when they are all the way down.
Anyone have any idea on what parts I may need to get these nice and tight again to prevent the rattling?
Much appreciated
bimanut
Mon May 23, 2011 6:55 pm
Mine front ones do this when i`ve got the top down,but i think it looks s**t with the windows up any way. :)
It`s more than likely to be the plastic guides on the rails are worn.
GDBN
Mon May 23, 2011 8:53 pm
Mine do the same. Just wind them down an inch and it will stop.
G
I deserve 6 of the best ...
DaveD
E30Zone Wiki Specialist
Mon May 23, 2011 10:50 pm
GDBN wrote:Mine do the same. Just wind them down an inch and it will stop.
G
+1
Bela
Wed May 25, 2011 10:03 am
Hi thanks for the feedback,
It rattles until all the way down : (
Bimanut, any idea on what the part number would be for the plastic guides?
**BANNED**
Wed May 25, 2011 5:40 pm
Check for part numbers on one or both of these sites.....
http://www.e30zone.net/modules.php?name ... c&t=189993
Youth is wasted on the young.
DaveD
Wed May 25, 2011 8:38 pm
could be that the window needs adjusting to p it at a tighter angle against the runner
http://www.e30zone.net/e30zonewiki/inde ... ont_window
sh55123
Sat May 28, 2011 8:39 pm
I have had success by adjusting the vertical angle of the rear windows (the centre torx nut at the bottom of the window glass). By adjusting the rear windows so that the top edge points away from the interior of the car by less than 1cm, when all the windows are up the front windows are gently levering the rears back towards the inside of the car, preventing rattling.
The only downside is that if you ever put the roof up when only the rear windows are up, they might need a slight push to sit in the rubber guides.
I can draw a picture if anyone needs me to, or you can look on the wiki at adjusting rear cab windows.
'87 325i cabriolet, manual, Zinnobar Red
'91 325i se coupe, manual, Laguna Green
