Easiest way to remove coupling from spline?
rancido64
Sat May 14, 2011 11:15 am
Just wondering what people find to be the easiest way to remove the steering coupling from the shaft/spline on the steering column?
Managed to get the bottom end detached from the rack handy enough but the top end is barely shifting off the spline.
Is it just a matter of brute force? Had a crowbar there and could've used that for the leverage to prise it off but don't want to damage the steering column by yoinking on it too hard or is that something i shouldn't be worrying about?
Any advice appreciated :)
Phil
Theo
Sat May 14, 2011 11:37 am
Blow torch to heat up the aluminium linkage, that'll do it.
Sat May 14, 2011 12:24 pm
Make sure you have completely removed the pinch bolt or it won't go anywhere
e301988325i
Sat May 14, 2011 12:25 pm
It's worth levering the split open with a large screwdriver to release it. This might be obvious, but the bolt sits in a groove and must be completely removed.
I said:
e30topless said:
lock the wife in there
rancido64
Sat May 14, 2011 12:28 pm
Aaah, so the bolt needs to come out altogether?
It's been loosened a fair bit and we wedged a screwdriver into the split to open it out a bit more, but as i said it still wouldn't budge.
Cheers guys
Sat May 14, 2011 12:29 pm
yes get rid of the bolt
Jozi
Sat May 14, 2011 2:44 pm
Have you started your conversion Phil?
Sat May 14, 2011 8:31 pm
The EASIEST and most NON_DESTRUCTIVE way to remove a steering linkage is to remove the RH rack mounting bolt and slacken the LH, swing the rack forward and the linkage will drop out with no hammers/pry bars/chisels/scaff bars or blow torches :roll:
Theo
Sat May 14, 2011 8:35 pm
:roll:
Try doing that on a car where the linkage is seized onto the steering column. It doesn't work.
Sat May 14, 2011 8:40 pm
Yeah, well you can use your hammer/blowtorch then innit winkeye
rancido64
Sun May 15, 2011 2:47 pm
DanThe wrote:The EASIEST and most NON_DESTRUCTIVE way to remove a steering linkage is to remove the RH rack mounting bolt and slacken the LH, swing the rack forward and the linkage will drop out with no hammers/pry bars/chisels/scaff bars or blow torches :roll:
This is what we did and while the bottom came off the rack no problem, the top end was being a right biatch :roll:
Things can never just be simple for me lol
Jozi wrote:Have you started your conversion Phil?
Slowly slowly catchy monkey :) Was supposed to lift the m40 out on friday but my mate couldn't get hold of the engine crane so we just made a bit more progress on getting it ready to be lifted out.
Pretty much all that's left is undo the engine mounts and lift it out 8)
