Splitting the rear brake pipes/bleeding
mattycoops43
Wed May 11, 2011 5:55 pm
Hiya
Quick question, I have picked up some rear wishbone bushes, and a diff bush, along with a complete set of stainless brake hoses.
I am thinking it would be nice to drop the whole subframe off the back and give it all a proper clean up and paint.
If I split the brake pipes where the first flexi is, onto the wisbone I guess? Will air seep back up into the system? I want to completely bleed all the old fluid out when new pipes are on, but I don't want to get into running abs pumps etc, so I want to keep fluid in the system.
Is there an easy way to do it? Can I leave the first flexi pipes on, to use brake pipe clamps while I do it, and still get the subframe off?
Ta
1990 325i se "weinrot"-How did they know?
ucpsale
Wed May 11, 2011 6:12 pm
You can pinch the flexi pipe with a set of mole grips
mattycoops43
Wed May 11, 2011 6:16 pm
yeah, I got a pair of proper pipe clamps for it, I was just wondering if I can get everything else off and leave that first rubber attached, or if I need to remove all the pipes back to the metal pipes to get the frame off.
penton08
Wed May 11, 2011 6:17 pm
As above, Or wedge the brake pedal as far down as possible with a bit of wood or something similar and leave it there until it is all put back together.
Wed May 11, 2011 6:23 pm
Ive got a lovely chunk of 4x4 just for this job :D
