310 brake discs and 16" wheels
vanos
Post Tue May 10, 2011 10:55 pm
Will 310mm brake discs fit behind 16" wheels, or do I need 17" wheels to be safe ?
craigieeb
Post Tue May 10, 2011 11:02 pm
What callipers are they?
you can get more than 310 behind a 16" wheel
All depends on the make/spoke design/ET of your wheels
vanos
Post Tue May 10, 2011 11:04 pm
craigieeb wrote:What callipers are they?
Wilwood calipars, ideally want 16" Hartge, otherwise some Alpinas.
Post Wed May 11, 2011 7:59 am
Hartges are a good wheel for fitting brakes behind, bigger than Alpinas on the rear
clarko74
Post Wed May 11, 2011 8:35 am
Like this:
I don't know what size discs they are but there may be some more info here:
http://www.e30zone.net/modules.php?name ... c&t=182762
clarko74
keri-WMS
Post Sun Jul 10, 2011 5:38 pm
clarko74 wrote:I don't know what size discs they are...
..they are almost 100% sure 298.5x20.5mm. You get a "virtual wheel spacer" from the thicker flange on the UK Wilwood kit bells, worth remembering if you want to maintain suspension geometry and also to make sure you get longer wheel bolts etc.
The 16" Alpina is a nightmare for fitting brakes, but both versions of the Hartge are pretty good, here's a 298.5x24mm WMS kit under the split rim 16", clears at the std offset (only needs a 1.0mm wheel spacer to get the thinner flange back to E30 offset so you can keep the std wheel bolts etc).
