tech 2 steering wheel horn.
shedrool83
Sun Apr 17, 2011 5:53 pm
How is the power feed to the steering wheel for the horn?
I have just swapped a tech 1 for a tech 2 and the horn isnt working on the tech 2.
I have tried just putting the 2 wires together but still nothing .
Anyone any ideas as i'm confused.
MurphyE30
Sun Apr 17, 2011 8:42 pm
i had the same problem when i fitted my Tech II wheel, i took the centre back out and re conected the conectors and after a short while it started to work.
thats probs not any help to you :mad: but it may start working suddenly :)
TDSCHRIS
Sun Apr 17, 2011 8:47 pm
i had a similar sounding problem when i changed from a standard wheel to a tech 2
mine was not earthing properly normally but was working when pushing on the wheel and depressing the horn at the same time
the power is fed by the contact on the column that rubs against the slip ring on the wheel
so i replaced the contact and the metal slip ring but still no different
i fitted a washer in behind the wheel and it solved the issue because it wasnt earthing properly through the shaft because the spacing wasnt brilliant
its important too makesure with the washer in that the wheel still fits the taper nicely
but thats what sorted mine out
**BANNED**
Sun Apr 17, 2011 8:56 pm
I had a problem with my tech 2 wheel as well!
The horn would sound randomly,usually at the most un-wanted times...and the steering felt dead,little self centring and 'lifeless'.
I fitted an extra washer under the wheel and all problems ceased!
Youth is wasted on the young.
shedrool83
Sun Apr 17, 2011 9:05 pm
Thanks for the info guys i'll try a washer under the wheel and see what happens.
