20/10 Electric sunroof sync - getting on my t1ts now !
Finally managed to open my electric sunroof today - very pleased that I've managed to get it working both sliding back and tilting after lots of persuasion, several hours, harsh language, a bust allen key and most of a can of WD40 its now sliding as it should under motor power.
However the motor appears to be out of sync - when it slides back you hear the relay click in about 2/3 of the way back and then again shortly afterwards.
How do I get it synced back up ? ( I had to undo the nut to "disconnect" it from the motor in order to move the roof with an allen key )
if you can close the sunroof to where you think it should be when not in use,
then remove the motor 3 screws hold it up , bit of a sad job to get to it,
while the motor is in your hand operate it to the closed/middle position, you will hear it click
it travels a short while when tilting and a long time for sliding you need it to be in the "middle" of these 2 operations
then re-fit and try
then re-fit and try
- **BANNED**
Unbolt the motor from it's frame,but leave it connected to power.
Motor has four 'movements'....
From closed;
Switch forward,short run to tilt
Switch backward,short run to lower
Switch backward,long run to lower and retract
Switch forward,long run to close the roof.
What you have to do is listen to the motor as you operate the switch,set the roof to tilt and the motor to the same position,re-fit the motor and test that you have got it right.
Remember that once the roof is running correctly,slide the liner forward,and lift the rear of it to engage the tilt levers,so that the liner lines up with it's fasteners.
From closed;
Youth is wasted on the young.
- **BANNED**
You have done well so far,once the thing is in sync,open fully,remove the stainless cover plates and grease the cables,be VERY careful of the stainless plates,the edges cut your pinkies for fun....and claret on the liner is a bugger to remove...
Didn't realise I could actually get at the cables to grease them - thats good. Will have a proper look maybe tomorrow - I just drenched all the moving parts I could get at in WD40 and moved it around a lot until it ran smooth.
Realised this was a bit of a dumb question now I've thought about it
Bump for this thread
Gonna start putting this back together very soon and want to sort the sync issue ideally before the headlining goes back in as I can get at the motor properly.
Do I have to temporarily refit the sunroof panel/liner to do this or will running the roof mech without the panel attached cause any issues ?
Ideally I want to get it synced, then all lubed, then refit the headlining, panel liner with the sunroof panel the last thing to go in - at least I think thats the way to do it
None of the headlining, etc., has to be in place. As said above, fully close the roof with the motor, unscrew the motor without disconnecting it electrically, set the motor to the closed position, and then refit it.
Only worrying part is how it got out of sync in the first place. Working it manually with the large nut slackened off shouldn't affect the sync.
- **BANNED**
I would assemble the panel to the mech,mount the motor,get it working properly,then remove the lid to aid access around the aperture.
Before you attempt to fit that re-covered roof liner,I trust that you will locate the mounting holes for the sunvisors....and mark accordingly....
At the moment I have removed all the screws which hold the mech in place ( had to in order to remove the old headlining ) - so the mech is all there but I cant risk moving it without screwing it all back into place.daimlerman wrote:I would assemble the panel to the mech,mount the motor,get it working properly,then remove the lid to aid access around the aperture.
Not sure whether I'm going to re-glue the new lining around the sunroof and under the door seals - there's still residue from the old lining there which I'm struggling to remove but I think the mech & door seals will hold it in place just fine.
Yes I'm going to mark up all the holes first Malc - I'm also going to install a drivers side grab handle as I've got spare ones from the bronze turd - and I've got to cut the lining at the back to get access to the dog guard mounting captive nuts - its marked on the reverse of the lining board but not looking forward to cutting it out
If the weather is OK this week I'm gonna try and get the carpet and dash back in first.
OK I've tried and failed to crack this today - I think the motor may be fooked.
Re-fitted the sunroof panel in fully tilted open position, dropped the motor, moved the motor to the first "click" ( its marked on the plastic cog which position is where ) and re-fitted - it works for one operation i.e drops flat then stops, slides all the way back and then stops where it should - it then goes out of sync again ! when you slide it back forward it doesnt stop in the closed position it just goes straight to tilt and tries to carry on which is what it was doing before - then when you close it again it doesnt stop at closed it carrys on sliding back to about 2/3 open then stops.
Is it the plastic cog thats likely to be fubar ?
The motor works fine but I'm guessing it will be easier to just fit a known good one rather than trying to take it to bits to replace the cog
Can anyone shed any light on this ?
- **BANNED**
Does sound as if the gearbox is not right,or the switching,I'm basing my previous posts on my work in transfering a known good power roof mech into my touring,that came with a keep fit version.
My problems centred around getting the mech sync'd to the motor,and getting both cables positioned correctly,then getting the tilt bits to lift properly...next doors kids were heard to ask for interpretations.....
Its very strange as on the first operation top drop closed and then slide back it works perfectly - its only when you slide it forward again it messes up.
I'm gonna go and have another look - back in a bit.
I think its the "gearbox" thats knackered - I can now see how it works with the microswitch for each part of the travel - however during part of the operation the plastic cogs can be seen to "miss" or "jump" which is what appears to be throwing the sync out.
New motor then by the look of it.
Brianmoooore wrote: Only worrying part is how it got out of sync in the first place.
Right this is getting on my nerves now.
Swapped the motor today for one bought from Alex - if anything its worse because the new motor does not appear to be as strong and just slips as soon as it encounters any resistance
Removed the plates which cover the cables, greased them with normal ( not copper ) grease and re-fitted the plates, re fitted the original motor which then worked properly for a few runs and then started acting up again.
I think this is probably down to the battery starting to run out - its as though if the motor encounters a bit of resistance when the roof is sliding the gearbox "skips" a tooth and knocks it out of sync - so obviously when the battery runs low any resistance will cause it to go out of sync sooner. The fact that it worked a few times is encouraging but its still not right.
Gonna put the battery on charge and try it again with the engine running.
In the meantime is normal grease the best thing to use to lube the cables or would WD40 or some sort of oil have been better ? - if so I'll wipe it off and re-do it
Ideally, you should pull both cables right out, wash all the old sticky grease off and re grease them from scratch. If the motor and the stainless steel plates are off, it's not much more work to unhook the cables and pull them out.
