6-Button OBC Fitting...
Ednamillion
Fri Apr 08, 2011 6:25 pm
Couple of things on this:
1. Is there anything in particular distinctly different between fitting the 6-button OBC to the 13-button (as per the Wiki)?
2. How would I know if I have an OBC relay?
3. Being just a 6-button, do I need the coding plug?
4. As an aside, if I was to use this opportunity to replace dashboard bulbs which ones/types would you advise I should get?
Thanks...
**BANNED**
Fri Apr 08, 2011 7:04 pm
Dash bulbs are 1.2w capless...
£1.08 each from BMW
£1.09 each from the local parts shop
£2.25 for 10 from the same local parts shop.....
I needed two,so bought ten,I still have a few left,I think.
Youth is wasted on the young.
Ednamillion
Fri Apr 08, 2011 8:56 pm
Cheers daimlerman.
Might I have read a post suggesting to replace with 3w bulbs...for improved, eh, brightness?
**BANNED**
Fri Apr 08, 2011 8:59 pm
Ednamillion wrote:Cheers daimlerman.
And melted plastics? winkeye
