the blue sensor
threelander
Thu Apr 07, 2011 5:54 pm
hi where is the blue sensor located on a m40 engine please.i refer to the blue sensor that can cause fuel issues and such.
cheers rich
Fri Apr 08, 2011 8:55 am
Well hidden under the inlet manifold, just above the join between the cylinder head and the block.
Ednamillion
Fri Apr 08, 2011 2:59 pm
This is a shot I took of mine: http://www.e30owners.com/forums/showpos ... ostcount=5
..it's the blue guy in the centre of shot down between the second inlet pipe from the front of the car and the intake boot (on the right of the photo).
threelander
Fri Apr 08, 2011 6:04 pm
can,t get photo up edna.and thanks brian.now do i need to take the inlet manifold off to replace it or can i do it without removing manifold.
thanks guys
Ednamillion
Fri Apr 08, 2011 6:28 pm
Sorry, should have come up on the post I linked to...
I haven't changed my sensor yet but I'm hoping a deep, 19mm socket probably with an extension on the ratchet will do the trick rather than removing the inlet manifold. I think I read same on here somewhere...
**BANNED**
Fri Apr 08, 2011 6:47 pm
Ednamillion wrote:Sorry, should have come up on the post I linked to...
You can certainly get to the blue sensor on an M50 this way,but I seem to remember having to invest in a deep 16mm socket!
Youth is wasted on the young.
threelander
Fri Apr 08, 2011 7:00 pm
19mm or 16mm which one.i think 19 sounds about rite
beer
Sun Apr 10, 2011 8:10 pm
sorry if i sound stupid but i am new to E30s
What does the blue sensor do?
beer
Sun Apr 10, 2011 8:12 pm
**BANNED**
Sun Apr 10, 2011 8:39 pm
beer wrote:sorry if i sound stupid but i am new to E30s
No question is silly or stupid if you do not know the answer.
Blue sensor measures coolant temperature and relays the information to the engine ECU,thus determining the amount of fuel that the injectors fire into the engine.
They tend to fail 'safe',thus fooling the ECU into thinking that the engine is always cold.
As mentioned above,they are well hidden on the M40 engine,but sit in clear view on top of the thermostat housing on the M20.
Ednamillion
Mon Apr 11, 2011 9:48 am
threelander wrote:19mm or 16mm which one.i think 19 sounds about rite
Always...but always....defer to daimlerman regarding these things. I thought I read 19mm somewhere whereas daimlerman has actually carried out the work.
And I haven't.
m8782538
Mon Apr 11, 2011 10:31 am
sorry for the hijack but on an M10 injection, is the blue one the one next to the brown one at the front of the engine bay near the fuel pressure regulator?
Ednamillion
Mon Apr 11, 2011 11:43 am
m8782538 wrote:sorry for the hijack but on an M10 injection, is the blue one the one next to the brown one at the front of the engine bay near the fuel pressure regulator?
Can't say for an M10 but on my M50 they are right beside each other towards the front of the engine alright.
**BANNED**
Mon Apr 11, 2011 12:07 pm
This is where they are located on M20,which is an M10 with the cylinder count corrected....
But I have not owned/worked on an M10 engined car!
vendetta
Tue Apr 12, 2011 3:51 pm
Yet again sorry to hijack another thread but could this be the solution to my problem also the temp gauge is vertually in the blue section
jann
Tue Apr 12, 2011 4:41 pm
vendetta wrote:Yet again sorry to hijack another thread but could this be the solution to my problem also the temp gauge is vertually in the blue section
I had this problem in the winter. A new thermostat cured it.
vendetta
Tue Apr 12, 2011 5:39 pm
Does the blue sensor have anything to do with duelling issues?
Tue Apr 12, 2011 7:44 pm
Blue sensor has everything to do with fuelling. If it, or it's wiring to the ECU is faulty, or if it's sitting in coolant at the wrong temperature, the fuelling will be incorrect.
vendetta
Tue Apr 12, 2011 8:19 pm
So maybe if I change that it might solve my running problems
threelander
Tue Apr 12, 2011 8:39 pm
sorry for robbing my thread back but brian is there anyway to test the sensor while still fixed to the car ie lecci testers and stuff
Tue Apr 12, 2011 8:57 pm
You can measure the resistance between the lead from the sensor and earth at the ECU plug with the engine cold and at full working temperature. I would expect a reading of around 3500 - 4000 ohms cold (at current UK daytime temperatures) and 330 ohms at full temp.
Pull the plug off of the ECU, measure the resistance, push it back on, run the engine up to full temp., pull the plug off again, and immediately measure the resistance.
I can't advise you on the ECU pin, as my M40 engine circuit diagram has gone missing, but it's a brown/red wire.
