M20 AFM setting, chip install
ETERNITY
Fri Apr 01, 2011 5:51 pm
I recently chipped my ecu by using a chip from Atech
After installation everything was fine, but last 2 days, its been kangooring, and rough on idle. Shaking side to side, and hunting. However it clears after 1000 rpm.
Ant told me to adjust my afm setting, and told me to adjust it by 1 whole turn.
Which way do i turn the setting nut and also do I need to reset the tps settings.
DaveD
E30Zone Wiki Specialist
Fri Apr 01, 2011 5:54 pm
sounds more like an air leak
ETERNITY
Fri Apr 01, 2011 5:55 pm
naa its running rich dave
No leaks, I have cheked
DaveD
Fri Apr 01, 2011 6:00 pm
mine failed its test on the same symptoms .,, running rich ,... lumpy tick over ..ok when run over 1200revs ...new throttle body gasket needed
ETERNITY
Fri Apr 01, 2011 6:06 pm
Ant did tell me to reset the afm, but he never mentioned which way to turn the afm setting
PG325
Fri Apr 01, 2011 7:42 pm
Counter clockwise will lean the mixture if you're running rich, I wouldn't suggest for one moment that you do this without having a gastester up it's ars*, and by this I don't mean a british gas employee!!!
Seriously though I would only adjust with a tester measuring the exhaust gases.
I did mine last weekend, I set it to 1% CO, adjusting just a quarter of the turn reduced it to nearer 0.6%.
ETERNITY
Fri Apr 01, 2011 7:44 pm
Ok i will wait till it goes in for Mot and have wait for the emissions report
jann
Fri Apr 01, 2011 11:54 pm
Hmmm this happened to me when I had my chip in the iS..although I haven't touched the afm, since it runs and idles fine without the chip in.
ETERNITY
Sat Apr 02, 2011 3:13 pm
Ant knows his stuff and he has told me to adjust the afm screw by 1 turn, but I forgot to ask him which way to turn and which screw to turn.
any ideas
Gristo
Mon Apr 04, 2011 6:05 pm
the adjustment srew should be under this cap(no. 2 on pict)
the more opened this skrew is, the more lighter your mixture is(more air, less fuel).
I dont know your chip settings so I'm not sure, will it need more air or fuel..
fix the screw present position start the engine and start turning this screw slowly on clockwise and opposite..you should hear the engine running more smoothly once..:)
hope it helps
ETERNITY
Mon Apr 04, 2011 7:32 pm
Gristo wrote:the adjustment srew should be under this cap(no. 2 on pict)
hope it helps
thanks for that
I have adjusted the screw and also the clog anticlockwise on the internals and its sorted the problem out(I think!)
will report back
Gristo
Mon Apr 04, 2011 8:43 pm
I'm happy for you,mate :)
ETERNITY
Mon Apr 04, 2011 9:03 pm
I am too, but seems as though accelaration doesnt seem as responsive
:mad:
i will have to let the MOT guys sort this out and set the afm accordingly
