hello
want asking why my engine has a tremor and I feel it at my steering wheel.
it is only below 1200 rpm only especially at idle, when i start to rev it will smooth.
does it is injector need to clean and calibrate? or something?
thanks
Markus
Tremor when idle but if it is above 1200 it is smooth
macas
was asking because I had the same problem with my m50 and found out it was my rocker cover gasket had gone and was seeping oil into the sparkplug wells,and they were full of oil,I cleaned them out and everything was fine!macas wrote:What engine is it my friend?
Probably not yr problem,but somthing to rule out.
