change over of complet auto/manual engines,
30e30
completed total changeover of knacked auto /manual more fun ,though on starting after reassembly ,the starter will not turn on the key,!!thus leaving me rather worried and shaken,as not experianced enough to try and delve into the electrics side,asking for any help ,advice or directions,cheers
beardymat
- Location: sheffield, city of steel, and rust apparently
have you just dissengaged the starter inhibitor switch at the gear selector?
i think you have to follow the wiring back to where it joins the main loom where you will find it connects to two plugs,unplug both from the inhibitor loom and you should be able to plug these into each other and this will bypass the inhibitor circuit
Remove panel above glovebox to expose wiring. Locate two single plug and sockets with black/yellow wires going to them.
Disconnect the sub loom from both of these plugs, and then plug the two connectors with the black/yellow wires together.
Rip out the sub loom and relay completely.
