rear disc conversion question?
zenyo
Wed Feb 23, 2011 10:47 pm
Right I have a 316i and I want to do a rear disc conversion, now if I change the rear arms I'm guessing my struts have to change aswell? Since the rear end will basically be a 325 and they have 51mm struts and mine are 45mm, there isn't anyway to keep the 45mm struts is there? Quick response please as I might bid on a lowering kit on eBay which is 45mm! But obviously won't if I can't use them, I kind of know the response il get I'm just hoping I can use 45mm still lmao :cool:
Sanchez
Wed Feb 23, 2011 10:48 pm
Your getting confused.
Struts are only fitted to the front of the car.
Topblag
Wed Feb 23, 2011 10:51 pm
Some people mistakenly refer to shock absorbers as struts.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
zenyo
Wed Feb 23, 2011 11:03 pm
Ahhh yes! You can tell I'm new to BMW's :D so I can still use a 45mm kit if I have a rear disc setup? Thinking of buying a cheap hot tuning kit just to get me slammed for a few months until I get more pennies for a gaz coilover kit :) :P
Topblag
Wed Feb 23, 2011 11:05 pm
get 51mm fitting shocks. They're really quite important to get right and the 45mm will rattle about in a 51mm strut at the front, which isn't good for a key suspension component, it just wouldn't work.
Topblag
Wed Feb 23, 2011 11:07 pm
oh, and don't buy cheap new shite from ebay, it's not worth it in the long run.
zenyo
Wed Feb 23, 2011 11:15 pm
Iv got a 316i so my front struts are 45mm was confused whether having a kit for 45mm struts would effect me having rear arms off a 325 ? 8O and the kit just temporary hopefully il get them for cheap so il just use and and abuse and bin :)
Thu Feb 24, 2011 7:48 am
Have you got the rear beam & trailing arms yet ?
I will have a setup for sale shortly and am not far from you :wink:
charlE30
Thu Feb 24, 2011 7:57 am
zenyo wrote:Iv got a 316i so my front struts are 45mm was confused whether having a kit for 45mm struts would effect me having rear arms off a 325 ? 8O and the kit just temporary hopefully il get them for cheap so il just use and and abuse and bin :)
Suspension kits designed for cars with 45mm struts will work perfectly fine on your car as you still have the original 45mm front struts. The back end of the E30 will fit perfectly, the fact it's from a 325i is almost irrelavant.
Make sure you order a suspension kit suitable for your 4 cyl 316i though as if you order a kit designed for a 6 cyl the front will sit too high.
HTH
Charlie
BMW F31 335d xdrive
tony83
Fri Mar 18, 2011 7:44 pm
iv gotn a 316 lux touring with discs on the rear on a 'k' reg not sure if thats standard on modified but they seem to work allright!
Fri Mar 18, 2011 8:34 pm
Topblag wrote:Some people mistakenly refer to shock absorbers as struts.
The 'shock absorber' is the spring winkeye
I think he means the damper
charlE30
Fri Mar 18, 2011 9:33 pm
tony83 wrote:iv gotn a 316 lux touring with discs on the rear on a 'k' reg not sure if thats standard on modified but they seem to work allright!
All tourer's came with discs and 51mm front struts as standard (basically the same as the 325i)
BMW F31 335d xdrive
