just fitted sump
slideways
- Contact:
is it the same sump??
if not the pickup could be against the base.
I assume you didn't put too much gasket sealer on have it squeez out and get sucked up into the pick up.
If not it could be airlocked. remove the oil light switch and with a squirt oil can pump oil down into the hole. only a thought but it could prime the pump
