m40 valve stem oil seals replacement
Fraz06
Tue Feb 22, 2011 5:56 pm
Hey guys, does anybody know how to replace worn valve stem oil seals in a m40 cylinder head? thanks in advance guys
fraz06
TheHeap
Tue Feb 22, 2011 6:29 pm
If i were to do it i would pull the head off. Others leave the head on and bring the piston up to stop the valve going into the bore.
Pull the head off and get a head gasket set, re-lap and reseal all eight valves and you should be good for another 70,000 miles.
Someone might be on in a minute to give much better advise and they'll probably ask why, meaning are you sure it's the sills and not the rings, etc, etc.
