how do you get a rad out of a 320i?
cheers ash
But before you do that, remove the two plastic rivets that hold the top of the shroud, unhook the bottom of the shroud from the bottom of the rad., and balance it on the fan.craigieeb wrote:With Tools
undo the water pipes, and the 2x10mm bolts that are on the top bracket.....
job done
