325 stalls and won't restart
VW-will
Hi guys, got my 325 in, but it's like it's overfueling, will only re-start when I disconnect the fuel lines for a bit..? Thanks
Ant
- Retired Team Member
gonna have to find the cause dude, overfuelling that bad so it stalls out will ruin the engine in quick time.
what's she run like from cold ?? only overfuelling when hot ??? defo overfuelling ( under can cause the same issues- not enough to burn properly so some gets chucked out again )
HELP US help you dude
Email FTW
VW-will
Really hard too keep it running on tickover, when it's hot it appears to run ok, previous owner of the engine said the cold start valve was dodgey would that cause this??
VW-will
Spoke to the dude who's doing some spraying for me, engine wouldn't start at all this morning am I right in thinking this is down to the coldstart valve..?
