I want to intall these but was unsure how they work?
I can get the actual mitrror glass with the elements and i have noticed that some wing mirrors have the wiring behind it in the mirror casing...but will it work if i just plug in the the new heated glass into the mirrors? Does it come on with the heated rear screen or does it have to work with a temp sensor like the one with the OBC? (which i am also yet to install)
Also is it the same for the heated washers?
heated mirrors and washers
bigwinn
heated washers plug straight into your washer jet motor loom, or if you have intensive wash function I think there is a socket on the loom for it?
Mine didnt come with plugs on it so I spliced it in to washer motor input
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
- E30 Zone Meets/Events Team
- Contact:
Mirrors are on as soon as the car is startedm the 2 extra wires to the element come of the main 4 motor wires in the housing.
- Contact:
Do you have the extra 2 wires???robsy wrote:Cool - so all i need to do is put the heated glass in and it will work??
They can be made up with spades on either end.
- threelander
no the mirror housing needs to be wired up to accept them.there are two wires that plug onto the glass yeh
