not strictly e30 but it will be used on it,
i have a compressor but im not sure which connetors go on which bit of the hose, compressor, tools etc....
any help would be brill!
e.
air tools
Hoggy
you normally put the male fitting on to the appliance(or tool),and female to the supply line.
A1BMW325iSport
yep as Hoggy says, i bought all mine from machine mart
kenwoir
HalFrauds do the bits you need aswell and they arent too dear either
elliot
right thanks boys.
could you fill in the gaps please
compressor needs a......
hose end (a) needs a.......
hose end (b) needs a ......
tool needs a................... male fitting
Templ8e30
Ok here goes,
compressor needs a female fitting
hose end (a) needs a male fitting
hose end (b) needs a female fitting
tool needs a male fitting
Hope that's clear
Cheers,
Iain T
Hope that's clear
Cheers,
Iain T
2007 Mazda 6 2.0 estate
It's good practice to fit a short piece of hose between the tool and the air connector, so that the connectors are not damaged by vibration or twisted while using the tool.
