OBC - changing display from KM to MPH ?
A1BMW325iSport
Post Mon Oct 03, 2005 11:59 pm
can`t seem to suss it out any ideas?
Demlotcrew
Post Tue Oct 04, 2005 12:03 am
consumption the press the little button you get m/g
A
smithy318i
press consumtion button then press the little button in the botom right corner (with a pen) until mpg is displayed.
btw you have to put up with the temp in deg F with miles... :cry:
dazleeds
old skool raver
old skool raver
Post Tue Oct 04, 2005 12:07 am
ive tried this before a few times and it didnt display mph??
www.oldskoolfantasy.co.uk
ShepsEvo3
Master of go faster
Post Tue Oct 04, 2005 12:14 am
Take a hammer to it! :twisted:
www.sabre-tuning.co.uk
A1BMW325iSport
Post Tue Oct 04, 2005 1:39 am
doesn`t work :cry:
if i do that it displays L:100 or L 100 as you press the little button with pen tip
then on main time display its says HEU insteasd of AM/PM ie 12.00 HEU
:mad: :cry:
ian332isport
Post Tue Oct 04, 2005 7:33 am
When on Consum, you should see three possible options when you press the little button in the bottom right corner.
One is the German setting that gives L:100, HUR & temp in degrees C etc.
The next is MPG & degrees F - this is the US setting.
Finally you should get M/G & degrees F - this is the correct UK setting.
Ian.
A1BMW325iSport
Post Tue Oct 04, 2005 10:46 am
no i don`t get those :cry:
