I've had my car geometry tested for its MOT, and I've been a really funky sheet of red and green numbers explaining how my suspension is set up.
Trouble is, it's all in Polish, and even though I can translate it, I'm still not sure what it means, or how to fix it. My rear wheel readings were:
Camber: -0.53 and -1.11, when the tolerance is -2.30 to -1.30
Toe: -1.05 and -1.33, when the tolerance is -0.04 to 0.26
All in all, I got a pass, but I've been told to "get it sorted, for the sake of your tyres." But how? Car's a 320i touring.
Excessive camber and toe at rear wheels - bushes?
Grrrmachine
- E30 Zone Wiki / Team Member
Is the rear ride height correct?
Grrrmachine
well, the rear suspension is unmolested in as much as I haven't lowered it, but the springs and shocks could be a bit saggy. What's the measurement for that (distance from arch top to the road, I presume?)
Grrrmachine
Never got confirmation of this; how to check and adjust the rear camber of a touring?
Morat
I thought rear camber was fixed?
(edit: unless you fit camber plates and wobbly bolts)
Grrrmachine
Well, I got a puncture today and noticed that the tyres are wearing unevenly; this is six months after I got the original geometry results, so I'm presuming they're linked. So if camber should be fixed, and it's wrong, how is it repaired? Is it most likely to be saggy springs, or bushings, or both?
Any accident damage?
Camber adjustment here - http://www.e30zone.net/modules.php?name ... c&t=134217
Grrrmachine
No accidents, just years of no maintenance, so it wouldn't surprise me if all the bushes are shot. I just don't know how to check, before I splash out on parts.
If they have never been changed then change them, they will need doing by now.
Grrrmachine
Yeah, that's what I thought. Big expense though, it seems, adding it all up. Oh well...
