Why wont my indicaters work ?
peejay
Post Fri Sep 30, 2005 8:46 am
Ive just driven 30 miles with no indicaters, not good. They were working fine last night, everything else is ok. Hazard warning works ok, lights flash with the alarm activation but no response when the stalk is used. All fuses are intact. Any ideas please folks ?
:cry:
Peejay.
Life begins at 40 ( to matter!)
Post Fri Sep 30, 2005 9:02 am
Fuse 4, 15A, is the fuse for the indicators. Check it very carefully. Often blows on late cars because of problems with the glove box light.
Other usual cause of total indicator failure is a dud hazard light switch, but there are plugs and sockets on the steering column that don't normally give trouble, but may have not been pushed together properly at some time.
peejay
Post Fri Sep 30, 2005 9:45 am
Cheers, I'll double check that fuse when i get a chance later. Funnily enough I did notice last night that my glove compartment light wasnt on but i didnt realise there may be a link. But having said that I'm sure the indicators were ok after I was in the glove box ! I'll report back.
Ta,
PJ.
peejay
Post Fri Sep 30, 2005 5:00 pm
Spot on Brian, although the fuse looks ok indicators work with replacement fuse...phew, can go home safely now ! The light in the glove box is hanging away from the switch, bulb looks ok will it be alright if I put it back ? I'm gonna leave it til later though time to go now.
Thanks Brianmooore, :D
Peejay.
Post Fri Sep 30, 2005 6:49 pm
Pull the fuse again before you put the glove box light back,or you will pop the fuse again. Don't be tempted to leave the bulbout either, as the holder tends to short circuit when empty.
This one catches quite a few people out, because the handbook doesn't list fuse 4 as being for the glovebox light.
In earlier cars (up to some time in 1988) it was on fuse 21 and the handbook wasn't updated after it was changed.
peejay
Post Sat Oct 01, 2005 8:27 am
thankyou, valueable advice... :thumb:
tomstickland
Post Sat Oct 01, 2005 11:31 am
Do you have a special edition BMW with functioning indicators fitted then? Maybe it's an ex police car or something?
peejay
Post Sat Oct 01, 2005 4:00 pm
Sorry....??
johnnyh
Post Sat Oct 01, 2005 4:15 pm
hi mate, i was drivin around for ages with no indicators. arm out the window job. found it, i replaced my glovebox, and there was a loose wire touching the metal catch. sometimes putting a new fuse in worked then that was it. worth a try for def mate. john
tomstickland
Post Sat Oct 01, 2005 4:59 pm
I was joking.
e30bb
Post Sun Oct 02, 2005 3:49 pm
Mines doing the same but, it blows again when u open the glove box.
Is my wiring wrong?
brown to side of the blub and the other to the bottom with small disc.
Post Sun Oct 02, 2005 3:58 pm
e30bb wrote:Mines doing the same but, it blows again when u open the glove box.
Is my wiring wrong?
Wiring's OK, bits are probably assembled wrong inside the bulb/switch unit.
johnnyh
Post Sun Oct 02, 2005 4:00 pm
have a good look around, as i said it took me months to find out what and were. it was a wire not connected up touching the metal catch.
e30bb
Post Sun Oct 02, 2005 9:35 pm
ok :?
