I have just bought my first E30 a 318is. Runs well but I think it could be better. Its a little hesitant at starting and I think it could be a bit more responsive. Any quick fixes on these engines or tips on making them run better?
Also if anyone happens to have a good silver bonnet and drivers side wing going spare. I'd be interested.
James
E30 M42 318i S Could it run better?
tomstickland
There are no quick tips. If it's new to you then I would suggest a full service:
-spark plugs
-HT leads if the current ones look old
-oil & filter
-coolant flush
-air filter
-gbox oil
-rear diff oil
The engine should pick up past 3.5K and revel in being revved.
It's amazing the difference basic servicing can make; I seem to be managing 3-4mpg more and gained around 8mph on top speed since changing the gbox/diff oil and fitting the correct wheels back on the car (less drag).
-spark plugs
-oil & filter
-coolant flush
-air filter
-gbox oil
-rear diff oil
kidsinister
adamS
leave the HT leads until last though. They are bloody expensive(Ԛ£90 from ECP) and you don't want to replace them unnecessarily!
tommo320i
I'm having an inspectionII done on mine on monday so I'll let you know the difference, oh chip and throttle body being installed too
darren318is
whats fuel economy like with abig bore tb on an 318is what gains and how much are they
kidsinister
redrobbie
yeh let us know, will be interesting to know if there is a difference.tommo320i wrote:I'm having an inspectionII done on mine on monday so I'll let you know the difference, oh chip and throttle body being installed too![]()
Guest
the chip makes a massive difference, i had hesitation like you described now its all fun fun fun!
tomstickland
Well, I've got the standard factory chip and standard throttle body and mine doesn't hesistate.
Fix any problems before doing chip swaps or tuning.
I doubt that a chip will gain you 15BHP.
