Right i've got a prefacelift Alpina C27. Car has been on carbs but returning to standard so fitted manifold and new wiring loom as old 1 was butchered. Problem i'm now having is that the fuel pump won't kick in from the ignition. If you bridge the relay it will start but as mentioned won't work from the key. Now i've checked all the earths and checked continuity of all the wires running to the fuel pump and main relays. So now basically i'm stuck. Can anyone point me in a direction of where to start looking.
Fuel pump not working
- **BANNED**
ECU switches the fuel pump when it sees the crank turning.
So I would start to look at the CPS and it's wiring.
Youth is wasted on the young.
- Brianmoooore
As daimlerman says, the fuel pump shouldn't "kick in with the ignition" - only when the crankshaft starts turning. Does it? If so, you are looking for a non existent fault.
- Brianmoooore
Some older versions might, but this is largely a myth. A fuel system in good order is capable of maintaining the pressure for several days.E30foz wrote:It should turn on for a couple of seconds to prime the system shouldn't it?
- Donnystreeterroist
havin a similar problem with my pre facelift 320, the fuel pump used to kick in when the ignition was switched on but now it doesnt, where is the relay located and does anybody have a wiring diagram for the fuel pump/engine ecu??
