First disaster - the distributor cap looked like it had been hit with a hammer - big cracks right across it.
One distributor rotor bolt undid OK. The others would not move, snapping one allen key and rounding off another. I got it off by dremeling a groove through the top and using a big flathead screwdriver.
Then the M6 bolt holding the upper timing belt shroud (to which the distributor mounts) sheared off in the head. The ez-out broke off in what remained of the bolt. Then a drill bit broke off in there too. Three hours later I gave up and left it there, now the shroud is held on with a cable tie.
Local parts supplier quoted > $600 for new distributor rotor and cap! I'll be waiting another ten days while it comes from Pelican.
And I got sunburned doing it. Bad day in the back yard.
And the water is still leaking.
