Pressure release sound from passenger footwell
mrogers
Tue Nov 02, 2010 7:14 pm
Happens when the brake pedal is pressed. also very little in the way of any brakes.
All help appreciated
gareth
Tue Nov 02, 2010 7:37 pm
The servo will make a slight 'pish' noise from behind the glovebox when you press the pedal, this is normal.
What's the problem you have with the brakes?
