easy question
abeazer
Mon Nov 01, 2010 5:49 pm
how do i remove my steering wheel?
318i wheel with the 4 horn buttons
thanks
steviebmw
Mon Nov 01, 2010 5:50 pm
IN THE CENTRE THERE WILL BE A BMW BADGE . TAKE THE BADGE OUT AND THE NUT WILL BE EASY TO GET TO
Ranchero
Mon Nov 01, 2010 5:53 pm
Prise the badge out, unscrew bolt, disconnect horn and pull off wheel. Take care when removing wheel as it can be a tight fit and may need a bit of force to remove. The danger is, it may come off suddenly and break your nose.
Ajsingh
Mon Nov 01, 2010 6:04 pm
Take off the bmw badge n loosen the, i think, 22mm nut.. With the nut still on, slowly pry the wheel off if its stuck on by moving it side to side... Easy...
Hopefully that wont take your nose out! Loll
E30 Crazy!
djscottfree
Mon Nov 01, 2010 6:15 pm
remember to remove the steering lock to pull it off
abeazer
Mon Nov 01, 2010 6:33 pm
okay thanks for the help just got to wait until the omp arrives
