OBC
zagorkaman
Tue Oct 26, 2010 9:51 pm
Any tips gratefully accepted.
My obc is very faded and does not work very well...ie i got half a tank of fuel and its telling me i got 49kms of fuel, can't seem to set time and date either...all a bit annoying when you have no clock......help anybody
Morat
Tue Oct 26, 2010 10:42 pm
It sounds like the bulb/bulbs have gone on the illumination bar behind the screen. The good news is that these bulbs are penny parts. The not so great news is that it can be a bit of a fiddle to get the OBC out to replace it.
Morat
Tue Oct 26, 2010 10:44 pm
Wed Oct 27, 2010 12:08 am
Morat wrote: The good news is that these bulbs are penny parts.
What Morat means is the the bulbs themselves are pennies from non BMW sources. The bulbs, soldered in place on a circuit board, are many hundreds of pennies from BMW.
zagorkaman
Wed Oct 27, 2010 6:38 am
Thanks for the help so far guys.........just one more thing, can the obc be replaced by the standard clock...i like clocks!!! and if so is there any demand for not lit 2nd hand obc units :mad:
Wed Oct 27, 2010 8:54 am
Clock connector (part of the main dash loom) will still be in there, hanging loose behind the OBC.
There's a good demand for second hand OBC units, complete with all their wiring looms and accessories. Just remove it all, and clip in an analogue clock.
zagorkaman
Wed Oct 27, 2010 3:20 pm
Thanks guys......not sure what to do now :cry:
johnt0709
Wed Oct 27, 2010 3:34 pm
keep the obc - all you have to do is replace the bulbs albeit they are soldered in.
My plan would be
1. Buy the bulbs
2. Line up someone competent to solder new bulbs in.
3. Take the obc out and at the side you will see a white plastic tag - grab this with pliers and pull out - thats your 'lighting board' out
4. Run car without the obc whilst someone solders in your bulbs.
5. Reinsert the lighting board, build up and bobs your aunty.
See if that cures it. Shouldnt cost much. Either that or get on the bay for one. but remember to swap over your coding plug, which is particular to your engine size.
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
eltel
Wed Oct 27, 2010 8:28 pm
about 3 years ago i bought the white bar with the 2 soldered bulbs direct from cotswold bmw in hereford and fitted them my self.. i paid somewhere in the region of £30-£40 if my memory serves me correctly.. i certainly would not have paid anymore!!
all i had to do was remove the obc (radio out + 4 small grub hex screws) slide out the old bulb rail and slide the new one in..simples!!
will check if i still have the reciept but def paid no more than £40
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
zagorkaman
Wed Oct 27, 2010 9:17 pm
thanks again for the help....if its 40 bucks and that simple thats the option for me.....i cant butter toast let alone solder on some fiddly little bulbs
Ty
