M20 Uprated Engine and Gearbox Mounts
- Brianmoooore
Standard mounts in good condition are well up to the job, especially if the engine mounts are fitted with the current spec. metal cups around them.
- Brianmoooore
which part am i looking at?Brianmoooore wrote:http://bmwfans.info/parts/catalog/E30/2 ... on_damper/
times getting shorter
The cups are a seperate item Numbers 12 (stopper / Cup) and number 7.
Genuine BMW mount will take all the abuse you can throw at them. Some ECP of GSF cheapies will not.
- Brianmoooore
As long as you keep all the M20 oil leaks away from them!B7 wrote: Genuine BMW mount will take all the abuse you can throw at them.
is the part number at the bottom of the page the genuine part number? so i could phone up bmw and order it?Brianmoooore wrote:http://bmwfans.info/parts/catalog/E30/2 ... on_damper/
- AlpineAde
For the sake of reference, I just had these fitted (comes a kit):
http://www.turnermotorsport.com/html/de ... 30325MMKIT
Mines had the cups since new.ImysE30 wrote:Or even Landrover Mounts?
The mount/cup is new, ordered some for mine that's got a M30 going in it, it can't weigh more than that
e301988325i
Thanks for the info, I won't be investing in them.Barton wrote:JUst out of interest, what do the cups do?
i expected them to be a snug fit around the rubber, but theres a 10mm gap all the way around
i really cant see them giving any benefit at all unless the mount fails
I posted this a while back. . .
e301988325i wrote:Cotswold BMW on here undercuts my local dealer even including postage! Shortshift kit using Z3 shifter is detailed in the wiki.
I've read that M20 E21 gearbox mounts are the same size, slightly firmer and more robust than E30 ones. Engine mounts are worth looking at too. There's a cheap upgrade available from www.burtonpower.co.uk that I use search for fp292
I said:
e30topless said:
lock the wife in there
