318is - 3000 rpm zizzing noise
cheesebox
Post Mon Sep 26, 2005 4:50 pm
I think this is a common problem but I've yet to find a definitive answer on how to fix it...
At around 3000 rpm there's a relatively loud "zizzing" noise. The rest of the rev range is lovely and smooth.
The following article (rival forum, sorry - will I get banned from e30zone?!) describes what I think is the same problem. Unfortunately it doesn't go in to much detail. Can anyone clarify what he's talking about? Eg a more detailed procedure, part numbers etc?
http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=08
Demlotcrew
Post Mon Sep 26, 2005 5:58 pm
Karan
tensioner
guides
try tensioner forst..... then guides
cheesebox
Post Mon Sep 26, 2005 9:03 pm
Thanks for the advice. Forgot to mention I've replaced the tensioner already - this succesfully got rid of the "hammer drill" type sound the engine made previously when cold. I also flushed the oil. So I guess it's the guides next.
Two questions
- is it worth changing the timing chain whilst I'm in there?
- are the guides - like the tensioner - the same as those on the M44 engine?
Thanks for your help!
jaistanley
Post Tue Sep 27, 2005 11:47 am
My is made the hammer drill sound till I replaced the hydraulic tensioner, all guides and chain. Now it makes the zizzing noise..
VERY annoying.
Assumed I'd tensioned the power steering and alternator belts wrong.
Bugger. Could it be a fault or a problem I'm just not gonna get rid of? Perhaps I need to adjust the new rubbery guide somehow?
Jai
cheesebox
Post Tue Jan 10, 2006 1:19 pm
jaistanley, I'd have thought the problem with yours must be down to wear on some other parts the chain is in contact with - it must be the 4 sprockets. When I get round to rebuilding mine I'll replace these as well.
Has anyone done this? If so, how big a job is it?
