I'm having a really bizarre experience with my car atm that's kinds hard to explain.
Basically the car revs but intermitantly the drive isn't there. It's a rapid on/off sensation as if I'm rapidly dipping the clutch in and out. The engine revs like it should though and it seems to run perfectly fine the majority of the time but occassionally I'll have this odd issue.
Has anyone got any ideas please?
TIA
Ant
Interesting issue.
Could be a failing ignition coil or loose engine earth strap, causing intermittent sparks.
Banjo1981
The rev counter behaves as normal, as if it's reving through the range as normal. The speedo also seems normal but does not tie in with the rev counter (if that makes sense) so, if my revs are at what I should be doing at 40 in say second I'm actually traveling at more like 20.
Are you talking of the infamous 'kangarooing' phenomenon, where it judders when coasting along in traffic?
Many E30s do this - there's a thread about it.
No, I meant just driving along slowly in traffic in say 2nd or 3rd gear, whereupon it will develop a juddering/shunting, making it awkward to drive smoothly.Banjo1981 wrote:Coasting as in not in gear? if so no, mine only seems to do it when in gear with my foot on the accelerator.
town325i
I had this issue on a 316i years ago found out it was a leaking slave cylinder ended up changing the clutch as it covered it in brake fluid.
This only happened when the clutch was hot ie when in stop start traffic.
Banjo1981
Ahh. Then no, it's a seperate issue to that.Speedtouch wrote:No, I meant just driving along slowly in traffic in say 2nd or 3rd gear, whereupon it will develop a juddering/shunting, making it awkward to drive smoothly.Banjo1981 wrote:Coasting as in not in gear? if so no, mine only seems to do it when in gear with my foot on the accelerator.
