318i m40 limpy on idle
jonny323i
Sat Oct 16, 2010 3:14 pm
what are all the common causes for the m40 running lumpy on idle
polsta
Sat Oct 16, 2010 4:35 pm
im no extert...
but get some carb cleaner, clean all the throttle housing and ajust it, and inlet thing inside the big rubber boot (the 2 flap type things that the throttle works) , clean the icv , and air filter, and check all the hoses and things like that
recently done that on myc ar and its running great
jonny323i
Sat Oct 16, 2010 5:19 pm
will do cheers sounds better than replacing parts
Kos
Sat Oct 16, 2010 5:32 pm
dizzy cap and leads can break down. i have a very very low milage set for sale, you just need to buy a rotor arm.
made a huge difference to my car.
also, the intake boot can split and cause an air leak which doesnt help the idle
www.pukardesigns.com
IG Pukar.Designs
TouringTash
Sat Oct 16, 2010 5:41 pm
whip off the rocker cover cap when the engine is on idle if it doesn't change lumpyness check for air leaks.
318i Touring
Kos
Sun Oct 17, 2010 11:45 pm
pm sent
IG Pukar.Designs
TimK
Mon Oct 18, 2010 8:22 am
I had this problem, I did all of the things suggested, and replaced the breather pipe to the idle control valve, adjusted the idle stop screw, and it's working fine.
Mon Oct 18, 2010 8:35 am
E30's DO NOT HAVE AN IDLE STOP SCREW! Leave this adjustment alone.
It was set correctly at the factory, and unless its already been got at, is still set correctly.
The same applies to the adjustment on the AFM.
If adjusting either of these results in improvements, you are just masking another fault, and making that original fault very difficult to find.
