325i manifold to 320?
koos
Post Sat Sep 24, 2005 4:54 pm
Does a 325i manifold fit a 320i, i wanna do the tb conversion to my 320i and was wondering if it would save me time in re-shaping my 320 one.
Post Sat Sep 24, 2005 5:50 pm
I shall be putting one onto a 320 head to go onto the 2.7 short engine I aquired last week. The manifold physically fits on the studs, but I imagine I shall have to blend the 320 head ports out a little.
Just guessing about the last bit, as I haven't stripped a 320 head off one of the engines I have here yet.
dazleeds
old skool raver
old skool raver
Post Sat Sep 24, 2005 5:57 pm
im 99% sure you lose powere by using the 325manifold as the ports are different hth D
www.oldskoolfantasy.co.uk
koos
Post Sat Sep 24, 2005 7:08 pm
what if i shape the ports to the head?
dazleeds
old skool raver
old skool raver
Post Sat Sep 24, 2005 7:34 pm
koos
Post Sat Sep 24, 2005 8:33 pm
does anyone have a copy of the article ??? should i just use a 320 manifold???
StuBeeDoo
Post Sat Sep 24, 2005 8:55 pm
I'm fairly certain that using the 325i manifold will loose power due to decreased gas velocity in the manifold runners (because the 320i doesn't "suck" so much), even if you do match the ports.
In Brian's case - using a 320i head on an ETA block - the 325i manifold would be the one to use if you're going for max power, rather than mid-range gains.
Therefore, on a 320i, use the 320i manifold.
Usual rules apply here - if I'm wrong, someone (Brian?? Ant??) please put me right and I'll be humble about it.
Stuart.
koos
Post Sun Sep 25, 2005 10:20 am
Thanks dude, think i will stick with the 320 manifold, anyone got one they wanna flog??
chieftouring
Post Sun Sep 25, 2005 5:40 pm
325 inlet manifold will give better power as will the tb if u match the ports even more bhp and from late 88 the exhaust manifold was the same on the 2.0 and the 2.5 ok m8.
