Running 17's ET40 4 x 100
Guest
Post Wed Feb 02, 2005 2:41 pm
Anyone had to order slightly over offset with spacers - I believe the correct offset is ET15 on E30 4 stud.
I'm interested in this wheel
Image but it will need spacers I believe...big mistake or worthwhile?
Guest
Post Wed Feb 02, 2005 3:05 pm
You will need 20mm spacer for et40. You should only get the hub centric type. I got momo ones with longer bolts and they are fine.
Guest
Post Wed Feb 02, 2005 3:16 pm
hub centric wheels or spacers (sorry a bit thick) - i take it the wheel supplier would supply the overlength bolts and correct spacers?
player6
Post Wed Feb 02, 2005 5:08 pm
you can get away with a 15mm spacer thats what im running
scot 328i with 260bhp
johnono
Post Wed Feb 02, 2005 5:16 pm
those wheels are lush underground! come on...price and where from!!
Ziggy
Post Wed Feb 02, 2005 5:19 pm
johnono wrote:those wheels are lush underground! come on...price and where from!!
From Rochford Tyres, I'm guessing!
http://www.rochfordtyres.co.uk/
Hub centric spacers - as opposed to just cheap plain ones that can cause balancing issues. :thumb:
Guest
Post Wed Feb 02, 2005 5:27 pm
Hi
I have et40 on my bmw. I tried normal flat spacers and they caused the whell to vibrate at higher speeds.
Hub centric spacers have a lip on them that correctly fit your wheel. They are alot more expensive than normal spacers, about Ԛ£60 inc longer bolts. Just remember that you will need longer lockers as well.
Guest
Post Thu Feb 03, 2005 9:24 am
you guys are sound!!! ps...my IRL name is Al lol lol
and I'm glad you like the wheel...
its so difficult getting the right look, but getting something different from the norm, but the right 'style', and i want to get it right first time... :thumb:
thanks for all the technical help too...especially the hub centric thing, i never knew about that.
