IBM/ Laptop with a DE-9 pin Plug for diagnostics connection
bigmace2004
Mon Sep 13, 2010 11:15 pm
Hi all, just wondering if any one knows what old laptop's have a DE-9 Plug connector Male, so my friend can get his diagnostics software working. Hopefully I can get a cheap one off the bay or someone. Ideally with windows 98
Looks like this serial port.
Ant
Retired Team Member
Retired Team Member
Tue Sep 14, 2010 10:04 am
most older Dell and Vaio have a comms port, as do the IBM T series.
you can use a PCIMCIA card to add a full comms port to a later laptop without a DB9.
DISABLE the onboard modem though whatever the case, can cause grief otherwise
schnaarf
Tue Sep 14, 2010 10:16 am
serial to USB converter? I use them for NMEA data input to my laptop and they work fine.
e21Jason
Tue Sep 14, 2010 10:48 am
I got pansonic toughbook cf-27 basic but great for the garage
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
bigmace2004
Tue Sep 14, 2010 12:09 pm
Cheers, very helpful, apparently he has tried the converter cable with no luck. PCIMCIA card seems like a cost effective route.
Tue Sep 14, 2010 12:18 pm
My Advent 6416 has one.
schnaarf
Tue Sep 14, 2010 12:23 pm
bigmace2004 wrote:Cheers, very helpful, apparently he has tried the converter cable with no luck. PCIMCIA card seems like a cost effective route.
I've found that some converters block certain languages which might be why your mates didn't work
bigmace2004
Tue Sep 14, 2010 10:15 pm
Ok Schnaarf what converter do you recommend
Ant
Retired Team Member
Retired Team Member
Tue Sep 14, 2010 11:18 pm
forget the USB route dude.
trust me, DB9 is the way forwards !
aeberbach
Wed Sep 15, 2010 1:44 am
Ant wrote:forget the USB route dude.
USB works fine. I've done many embedded projects requiring a fully programmable serial port and Keyspan's USB-to-serial adapters are great, even the four port version is good.
