warning light help!
r0fffles
Mon Sep 13, 2010 7:13 pm
well the light thats comin on is lightin up after about 2-3 mins of drivin were before it used to just come on when i turned ignition on then went off once i started the car
its the Green light far left
r0fffles
Mon Sep 13, 2010 7:20 pm
oh yeah forgot to put its a 325i G plate
**BANNED**
Mon Sep 13, 2010 7:59 pm
Standard Engine?
Youth is wasted on the young.
r0fffles
Mon Sep 13, 2010 8:16 pm
yeah no mods to it at all
**BANNED**
Mon Sep 13, 2010 8:51 pm
Strange.
I have only ever seen that light used as a check light on M50 conversions,to indicate a sensor issue.
On a standard car,the light is blank.
HJG-E30
Mon Sep 13, 2010 9:26 pm
I never knew this light even existed!
r0fffles
Mon Sep 13, 2010 9:32 pm
this is what is why im a bit worried it comes one everyday when i turn ignition on then goes off once started but came on while i was goin down M1 on way home from work i wasent doing anything differnt to normal an then it came on again when i went to shops later on
HJG-E30
Tue Sep 14, 2010 1:11 pm
It's not mentioned anywhere in the owners manual? I haven't got one to hand...
TopSod
Tue Sep 14, 2010 1:52 pm
I could only find an American PDF, so dont know if it will be the same or not, and dont have my book to hand.
http://jon.bimmerfest.com/bulletins/e30_manual.pdf
r0fffles
Tue Sep 14, 2010 3:38 pm
manual seems to mention stuff about it been for diesels :s
Tue Sep 14, 2010 3:52 pm
That looks like No 10, emissions based :?
Martain
Tue Sep 14, 2010 7:54 pm
just out of interest but the light that isnt lit between the two red lights under the rev counter what does it mean if this is lit ???
HJG-E30
Tue Sep 14, 2010 7:58 pm
To the above post..... Brake pad warning light. Extremely common for these to be lit all the time. There is a mod to stop it I think, but many owners live with it!
Martain
Tue Sep 14, 2010 8:04 pm
thanks very much had wondered what it was sorry for hi-jacking post
Tue Sep 14, 2010 8:50 pm
That green light should only be on the oil burners. It comes on after the glowplug light goes out, or comes straight on with the ignition switch if the engine is already warm enough not to need preheat. It indicates that the engine is ready to be started.
Chris-W
Tue Sep 14, 2010 9:01 pm
I wonder if someone has plugged the abs lamp into the wrong hole in the cluster at some point?
Tue Sep 14, 2010 9:06 pm
Chris-W wrote:I wonder if someone has plugged the abs lamp into the wrong hole in the cluster at some point?
Since I now see that this isn't an oil burner, that seems a very likely explanation, Chris.
So we now have an ABS sensor fault!
Chris-W
Tue Sep 14, 2010 9:07 pm
Quite. Assuming ABS on the car of course.
TopSod
Tue Sep 14, 2010 10:29 pm
Or the clocks have been changed from a diesel? Or both!
**BANNED**
Tue Sep 14, 2010 10:46 pm
Some oil burner with a 6.5k redline :mad:
Tue Sep 14, 2010 10:54 pm
Id say the breadman has it in one :D
r0fffles
Tue Sep 14, 2010 11:04 pm
id does have abs yes but i assumed it didnt work as it locked up under hard breakin
Tue Sep 14, 2010 11:11 pm
Your MOT tester has fallen down on the job! Car should have failed it's test with an inoperative ABS warning lamp. (The unlit one below the gap between the tacho. and temp. gauge.)
r0fffles
Wed Sep 15, 2010 8:31 am
right so how do i even go about sortin this out first of all do i have clocks out to check the bulb? then is it a case fo checkin all the abs sensors for broken rings an wires? or is there a common problem i should check first?
Wed Sep 15, 2010 8:53 am
It would be a good idea to put the bulb back where it belongs. You may be able to do it just by removing the panel above the driver's knees, with the aid of some needle nosed pliers and great care. The complete lampholder just pushes in its hole, and is held in place by friction alone.
If it is the ABS light, the wire colours should be green/red or grey/red and green.
To start fault finding the ABS, take off the inspection cover above the glovebox, and the ABS ECU will be right in front of you. Remove its connector, and measure the resistance of the ABS wheel sensors across the following pairs of pins of the plug:
4 and 6 = LF
8 and 9 = LR
11 and 21 = RF
24 and 26 = RR
The resistances should be around 980 ohms, but more importantly, should be identical.
Take care not to spread the buckets in the plug with your meter probes.
r0fffles
Wed Sep 15, 2010 3:30 pm
will give that a go an let you know how i go on cheers for your help !
